Using sculpt to bend a part
vanzeeem
Observer Observer
vanzeeem
Observer
Observer
I am relatively new to Fusion 360 and am attempting to self-teach myself how to use it well enough to create component drawings for some parts I need machined. One of the parts (shown below) needs to be bent to create a j-hook on the left side.
Since I need component drawings of the part before and after bending, I first created the above part and then inserted it into a new design to make that file the bent piece. I unlinked the part from original, turned off design history, and converted the part from BRep to T-Splines. Then, using sculpt I attempted to manually bend the left side up into the j-hook. However, the T-Splines end up only being a "skin" and the part itself does not bend, as shown in the picture (this isn't the actual shape I need it to be, just wanted to show what happens).hhh hau bent.JPG
Is there any way I can get the end result that I need without having to redraw the entire part from scratch as bent? Any help is greatly appreciated, thanks!
TrippyLighting
Familiarize yourself with the sheet metal work space, which deals with such parts.
Sculpting will no get you what you are looking for.
