Message 1 of 8
I scanned wall tile around an outlet with a 3DMakerPro Mole scanner. I've inserted the .obj mesh and converted it to a surface. I am trying to make a spacer to fit the contours of said tile for the plate cover to rest on, but Fusion crashes each time I try to run the Replace Face command most likely due to the fact the surface has hundreds of thousands of faces. I'm open to any and all suggestions.
