Cannot create sketch on surface
kmanuele
kmanuele
I am trying to create a sketch in one of the roots of this gear, in order to place a hole down to the bore.
I can highlight that surface in the root but it thinks a sketch already exists there, and I can't create a new sketch. Can't create a sketch on the tooth tops either.
However, I can create a sketch on the sloped gear faces.
The gear profile was originally sourced from a manufactured component, projected onto a sketch, and new component created.
?? Ideas
Thanks in advance
Kevin
TheCADWhisperer
@kmanuele
The roots are cylindrical faces, not planar faces.
Also, many of your sketches are not fully defined?
kmanuele
Ok. I see that. Should have done a simple measure before posting.
