Using Prusa Control in the 3D Print
I use Fusion 360 for making models to be 3D printed. My printer is a Prusa i3 MK3. I like to use the 3D Print command under FILE. Here you can choose which program to export the STL file too. This worked very well using the RepitierHost. Now with my new printer I wish to use the Prusa Control program. I have selcted CUSTOM and pointed the application to PrusaControl.exe. The Prusa control is found and starts to load but then stops for some reason. How can I add Prusa Control to the Print Utility?
etfrench
What are the command line parameters for the Prusa program?
This thread is about using Slic3r, but it may help.
ETFrench
