There's got to be a simple solution this, but I've yet to find it. Reference the picture I've attached:
I basically just want to position that little peg that's free-floating underneith the shelf above it and against the pegboard on the left offset about 0.25" back. Normally in Solidworks, I would just mate the left edge of the peg with the right edge of the pegboard, the top of the peg with the bottom of the shelf, and offset the front face from the front of the pegboard by 0.25". I can't figure out how to do that with joints. Closest I can think of is to mate the top corner of the peg to the bottom corner of the shelf, but the shelf isn't flush to the pegboard whereas I want the peg to be flush to the pegboard and flush to the underside of the shelf. I thought I could define a joint location, but as the picture shows, I can't seem to select anything to snap to. I've seen other pictures that have X,Y, and Z distances in the joint origin window, but I can't seem to get those to pop up.
Similarly, I need to align these two towers: (just to clarify, to not have the process come to a stop, I just made the pegs mentioned above flush so I could move on with the model)
at about 45 degrees to the edge of the base and have them sit flush on top of the base offset by some distance from the corner, about as pictured but flush to the top of the base. I also can't figure out how to do this with joints. It needs to be a rigid joint, but offset at both an angle and a distance.
In general, I feel like I'm having to think way to hard to come up with a way to join components without mates. I would like to get these issues figured out, because this is just modeling what I've alreayd built. My next step will be to take this design and change the dimensions and some parts of the design to increase the overall capacity without increasing the stand's footprint. That will required a lot of arbitrary component placement that Fusion 360 doesn't seem to be able to do, at least to my limited knowledge. In Solidworks with the mates it's all easy to do, but without them... Anyone have any ideas? I'm at a loss. I'd greatly appreaciate any assistance I can get.
