using a coverted .stl as a split tool
fhammond70
fhammond70
I have an STL file that i want to use a split tool, but Fusion flakes out and I get a black screen.
the converted stl has a large amount of triangles, and the model being split was designed in fusion as a solid model.
I am trying to copy the curve from the converted stl to my solid model
I have a i9, 18 core PC with 64 gig of ram. fyi.
I turned off design history
here is the link to download
https://a360.co/3uukb1k
what is inside the converted .stl mesh is what i am trying to keep.
I have always had a difficult time working with stl files even after i convert to solid ....  what am i missing?
TheCADWhisperer
What do you observe when you examine the geometry?
Here is what I observe.
No curves, not a single one. Zip, Nil, Nada.
Only straight lines and thousands of faceted planar triangles.
I would expect to see smooth flowing curved geometry for a design like this.
I thing the GIGO Principle applies here.
If this were my work - I would use the stl only as reference in recreating proper high-quality geometry.
wersy
To reduce the mesh and make it editable, I reduced it and converted it back to solid.
Created 3 sketches and made a loft.
Then I cut out the part.
I think that might be accurate enough.
