User parameter: random
nkloski
Message 1 of 14
nkloski
Hi all....I knwo that one can enter in mathematical formulas into various places in Fusion 360.
Is there a "random" value I can put in/use to create some organic randomness?
Thanks!
Nick Kloski
Replies (13)
Message 2 of 14
martin.zatecka
I'm not aware of any random variable. However it is interesting idea. I would like to have the "random" variable oscillates in defined range of min and max.
please put your idea to http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125
regards
Martin
Martin Zatecka
UX Designer
Message 3 of 14
nkloski
Done! Thanks!
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/please-add-in-quot-random-quot-number...
Nick Kloski
Message 4 of 14
HughesTooling
There is a random() Function available. Click on learning at the top of the screen, then form + modify panel  + change parameters for a list of functions.
Mark.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 14
HughesTooling
Ok just tried to use the random function and it makes Fusion crash. I set up a user parameter and random seems to give a random number between 0 and 1 but if you try and use it as a dimension eg. set up a parameter test using random() the in dimension use test*10 fusion crashes.
Mark.
Mark Hughes
Message 6 of 14
martin.zatecka
Hello Mark,
thank you for your comment. My mistake, I missed the information about random() variable.
Please would you help me to reproduce the crash of Fusion?
I setup this example without any followed crash.
thank you
Martin
Martin Zatecka
UX Designer
Message 7 of 14
HughesTooling
Hello Martin
I tried to enter the equation directly into a dimension. Example draw a line, select dimension tool, pick line and type test*10.
Mark
Mark Hughes
Message 8 of 14
martin.zatecka
nice catch 🙂 I'll ask for fix.
thank you
Martin
Martin Zatecka
UX Designer
Message 9 of 14
nkloski
Thanks! Yes, that does return a random number...is there a way to get it to (as suggested by you, Martin) oscillate between a certain range?...or just to return a number like "42" or "75"?
I tried using the "round" variable, but that did not seem to get the right response, it only returned numbers that were divisible by 10 (20, or 90, or 70).
Nick Kloski
Message 10 of 14
martin.zatecka
Let's try this:
random() returns numbers from 0 to 1
set maximal and minimal value, the formula "( random() * ( maxRange - minRange ) ) + minRange" calculates value in range of min and max.
for example:
random = 0, min = 10, max = 20
formula: 0 * (20 - 10) + 10 = 10
random = 1, min = 10, max = 20
formula: 1 * (20 - 10) + 10 = 20
Do you want to adjust it, or it is ok?
regards
Martin
Martin Zatecka
UX Designer
Message 11 of 14
jeff.pek
Hi -
Typically, this would be done by multiplying the random number by the difference between the min and max values, and adding the min value. This sample is from a different language, but clarifies the approach:
// Returns a random integer between min and max
// Using Math.round() will give you a non-uniform distribution!
function getRandomInt(min, max) {
  return Math.floor(Math.random() * (max - min + 1)) + min;
Hopefully we support the floor() function!
 Jeff
Message 12 of 14
HughesTooling
I just trird round and it seems to work ok.
Mark.
Mark Hughes
Message 13 of 14
nkloski
Awesome!  Thanks, all!
Nick Kloski
Message 14 of 14
joeX8245
Was this ever solved?
There are times where having  a randomly generated number that varies (in a range) when applied to a pattern for example would be very useful.
My goal is to have radii extend from a center point in random intervals between 15 and 25 deg.
I tried using: ( ( random() * ( ceil(25) - floor(15) ) ) * 1 deg ) + ( floor(15) ) * 1 deg
The formula compiled, but when I inserted it into the patterning tool, I got one value repeated.
Could we add 'noise' as a variable?
I can imagine with some rounding and constraints, that could would provide a sample 'set'.
Is there a way to do this in Python or Java?
