Showing results forĀ
Did you mean:Ā
Useful enhancements
2 REPLIES 2
lemelman
169 Views, 2 Replies
Useful enhancements
In 2D drawings, when I create section view, I can only move that view along  a line parallel to the direction arrows. I would like to be able to move the view to a location of my choice, as I can with the section identity.
In the model environment, when I've created a number of components that need to be 3D printed, it is very tedious and time consuming to have to select each one in turn in order to save-as-mesh. It would be much nicer to select all them and save the lot in one go - and end up with separate STLs for each one.
2 REPLIES 2
nemadec
in reply to: lemelman
Hi @lemelman
If you want place sectional view other parallel direction, than while placing you just need to press "Shift" once.
please refer attached video.
this also applies on projected view as well. (Place Projected view--> while dragging press shift --> you can place view as per you requirement)
Hope this resolve one requirement.
Chandrashekhar Nemade
Sr. SQA Engineer
Tags (1)
lemelman
in reply to: nemadec
Thank you. Now why isn't that made more obvious?
Technology Administrators
