Use svg to create a body
jdaues
jdaues
I have an svg file that I want to use to create the shape of a body. When I Insert svg, I just get a circle. What am I doing wrong?
I get a "The attachment's .3mf content type (application/octet-stream) does not match its file extension and has been removed." error when trying to attach a 3mf file, so instead I've put it here
davebYYPCU
Worked as expected here. Arrived no error, has 3 profiles to select.
Might help...
pkomatlapalli
Hi @jdaues,
Can you please confirm whether davebYYPCU   response addresses your issue. If yes, please consider marking it as the "Accepted solution" button. Doing so helps other community members quickly identify the most relevant answer and serves as a useful reference for users facing similar issues.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
