URGENT!! SNAP CLIP DESIGN
Hello!! I need a Fushion360 design of snap clips which are found in baby clothes (see photos attached). Diameter must follow the T-15 guidelines (12mm). I would also like for the caps to be as flat as possible!! I am not that experienced therefore can't design it myself. Is there anyone that already has a design or is whiling to help me out! It would mean a lot!
Thanks!
daniel_lyall
https://www.youtube.com/results?search_query=fusion+360+revove
https://www.youtube.com/watch?v=HVEaYfdsgXc
https://www.youtube.com/watch?v=1KHvJqKFS1Q
These will help you learn what to do.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
daniel_lyall
Daniel Lyall
The Big Boss
Mach3 User
wmhazzard
If you sketch the cross section of the clips, you can do a revolve and model the clip in one operation.
chrisplyler
Presumably, there would be a desire to have each part be a separate Component. So you could use a single sketch, but four separate Revolve operations.
