Upload Slow and/or Failures
bverboort
Message 1 of 21
bverboort
Using the upload workflow for bringing existing models into F360
I'm seeing very poor performance.
looooog upload times and failures
Even a tiny text (.txt) file is slow/failing
Anyone else?
Best,
Brian
Replies (20)
Message 2 of 21
HughesTooling
Does seem a lot slower than it was a few weeks back.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 21
Sandflo
Hi Brian!
i had som problems with that aswell, the solution for me was to do i "clean" reinstall. then it worked.
I dont know why it did't work in the first place, but i hope that the people at autodesk is looking in to this...
See my thread here
http://forums.autodesk.com/t5/general-fusion-360-questions/open-step-files/td-p/5455742
__________________
Gigabyte P35 V3 , Windows 8.1, Sweden
Message 4 of 21
Sandflo
He email me how to do a clean reinstall
Clean Uninstall Directions:
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
This will  manually delete all the Fusion files on your system.
__________________
Message 5 of 21
bverboort
Thanks!
Message 6 of 21
schneik-adsk
Before doing a clean please collect the log files using the help menu and send them to me. that way we can debug what may be going wrong.
Kevin Schneider
Message 7 of 21
bverboort
Oops...
Message 8 of 21
l_wcrenshaw
I'm seeing the same problem.  I've tried uploading ~10 Inventor files--all failed.  Converted all of them to STEP files in Inventor--all uploads failed.  Opened all of the STEP files in SolidWorks successfully.  Reconverted the SolidWorks STEP file imports into STEP again.  Uploaded the SolidWorks STEP files--successful.
Can someone look into this as I don't really want to perform a uninstall/clean reinstall?  I'm especially concerned about the Inventor imports b/c that's what I really need.  Thx.
Lew
Message 9 of 21
bverboort
A clean reinstall seems to have resolved my issue.
I suggest we follow schneik's advice (above) and collect/send the diagnostic logs _before_ doing a clean reinstall so Autodesk has something to help them sort this out.
Best
Brian
Message 10 of 21
Sandflo
Yes i'm sorry that i didn't remember the log file upload, but glad that the reinstall solved your problem
__________________
Message 11 of 21
innovatenate
Autodesk Support
Autodesk Support
You can get them by using the Diagnostic log file command form the help drop down menu (see image below).
They will help us analyze what may be happening.
Nathan Chandler
Principal Specialist
Message 12 of 21
l_wcrenshaw
Well, apparently that worked.  The Inventor and Inventor generated STEP files that previously failed to upload, uploaded successfully.  Enlcosed is the log file.
Lew
Message 13 of 21
I am having files load for hours. Is there any way besides doing a clean install to get around this problem?
Attached is my log
Message 14 of 21
prabakarm
Thanks Matt and lwcrenshaw.  The development team is looking into it.  We will get back to you on the problem and any other workarounds before we fix the problem.
Prabakar.
Message 15 of 21
matt.pooley
Hi Matt,
I took a look at our logs for the models which are mentioned in your log (Tesla Plate.dwg and Tesla Plate.dxf).
Both of these files failed to translate into Fusion 360 format, there should be PDF files containing additional information on what failed in your side panel. (If you don't see them, you might need to hit the Refresh button).
If you aren't sure why the translation of these files failed, you could send one to us for investigation.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 16 of 21
matt.pooley
Hi Lew,
I went digging into the log files you supplied and am seeing something interesting both in your logs and in our server side logs. Specifically, values which we expect to be numeric are including numeric seperators (e.g. 2,606 instead of 2606). On my Windows machine, I've made some configuration changes to try and reproduce this, but haven't been successful.
Do you have any ideas about settings on your system which could be linked to this ? If we can identify how to reproduce the situation then we should be able to find a resolution.
Matt Pooley
Message 17 of 21
l_wcrenshaw
Can you be more specific with regard to the settings you're interested in?  The files that failed to upload were all Inventor files or Inventor generated STEP files.
R/,
Lew
Message 18 of 21
matt.pooley
Hi Lew,
The settings I'm interested in are in the 'Region and Language' settings in the Windows Control Panel, I'm not certain where they are on a Mac computer (but I can find out if that is relevant for you).
Specifically, I'm interested in the Additional settings on the Format tab and the 'Language for non-Unicode programs' setting on the Administrative tab.
Matt Pooley
Message 19 of 21
l_wcrenshaw
Is this it?
Message 20 of 21
Sandflo
Hear are my setting, I had to do a clean uninstall to get it to work
__________________
