I did receive the files. I apologize for the response time, I needed to escalate them to someone with a bit more expertise. At this time,
I think I have a solution for you. It looks like Fusion 360 is trying to upload a design that isn't there.
From this message in the log:
ERROR: Empty toUrl, upload aborted!! linkinfo: { linkName: 3159f240-7db1-433c-a8e6-84f70c62ad30_urn:adsk.wipprod:fs.file:vf.hwwc_bNjRGGmChLsj9iHLw?version=55, fromURL: ***/Application Support/Autodesk/Autodesk Fusion 360/***/CrashRecovery/8f41d6cfe8f849c68101a34abbae9c14.backup, toURL: ***/Application Support/Autodesk/Autodesk Fusion 360/***/W.login/F/2/_BA_Premium_03.0d2e1748-3ddf-49c9-99fc-88165b106826_LV24.f3d, resolvedToPath: ***/Application Support/Autodesk/Autodesk Fusion 360/***/W.login/F/2/_BA_Premium_03.0d2e1748-3ddf-49c9-99fc-88165b106826_LV24.f3d
We, can see that Fusion 360 is looking for a file _BA_Premium_03.0d2e1748-3ddf-49c9-99fc-88165b106826_LV24.f3d
at
Macintosh HD > Users > ***> Library > Application Support > Autodesk > Autodesk Fusion 360 > *** > W.login > F > 2
However, the file does not appear to be in this directory as expected. Instead it appears to be located in the "1" directory:
Macintosh HD > Users > ***> Library > Application Support > Autodesk > Autodesk Fusion 360 > *** > W.login > F > 1
To fix the issue:
1. Close Fusion 360
2. Make a Copy of "2" directory
3. Rename the copied folder to "1"
4. Restart Fusion 360
This should help get the uploads started again. If there are still problems uploading files after doing this, please do the send me another copy of the updated diagnostic log files.
I hope this helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
