Upload hung
Upload hung
Upload hung
How can you force cancel an upload?  I have a few stuck (for 2 hours now) and won't finish.  Others upload just fine.
Jon.Dean
If you close Fusion 360, you will be asked if you want to quit the uploads, the uploads will resume next time you log in.
The next time you log in may establish a better connection and finish the job.
Jon.
Jon Dean
?want to stop upload no green x
Roman_Vesely
HI machineshop,
 for this case, when you want to terminate Upload, you can use command "Clear user cache data"
you should see this warning message:
Press "Restart to clear cache" button.
Be careful, all documents in Upload queue will be deleted.
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
Jon.Dean
Hi Machineshop,
Did Roman's solution resolve your issue?
If so then please "Accept as Solution".
Cheers
Jon.
Jon Dean
