Now that we have the option to create drawings from/with surfaces is it possible to have now a filter to select only "surfaces bodies"?
Drawings
Opening an simplified export drawing from Fusion will turn/convert some of the splines from the drawing into arcs and will also be "disconnected" where some splines join, see attached drawing...I need to find the one where the join is disconnected
Thank you
