Unjoined faces
Unjoined faces
Unjoined faces
I can't join the two faces of one bodie (the one in red and the one in green). This line prevents me to draft the surface. I think this is not due to an angle defect because the faces seem coplanar.
If someone could help me I would be greatful.
Theophile
TheCADWhisperer
Faces not co-planarNot CoPlanar.PNG.
Thank you for your reply. I saw that too but i didn't find the reason of this non coplanarity. so i thought it was an aproximation failure. If you know why there is an angle it would help me a lot.
Thanks, théophile
TheCADWhisperer
I didn't see the cause, but I can tell you that I would start over from scratch if it were my model.
I think you can significantly simplify the modeling steps.
TheCADWhisperer
I experimented a bit (see Attached).
Hello the cad whisperer
Thank you very much for your quick reply, it helped me a lot.
sincerly yours
