Units conversion on input
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When putting in dimensions I can put in different units then what I am working in and that works fine.
For example, my sketch is in mm and I draw a circle, but I want to specify the size in inches, that works just fine. Where I want to see the change is when I EDIT the dimension of the circle. It keeps the size in inches. I would like for an option to convert it to mm so that when I edit it, I can edit the value in mm and not inches.
This came up when I was looking for a size of a bolt and the first result I found was in inches, so I just used that to create the circle. However, I needed to tweak the design a bit and wanted to do it in mm.
Brien King
spammehere@arcaderestoration.com
http://www.arcaderestoration.com
