Unit in csv data
Unit in csv data
Unit in csv data
I used ImportSplineCSV add-in and found that the imported spline turned ten times larder than the original data.
The unit used in the original csv data is mm.
Did ImportSplineCSV interpret it as cm?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
I believe Fusion reads all unitless files as CM, which would explain the 10x larger in size difference you are seeing! One quick workaround however would be to use the "Scale Sketch" function in the sketch menu to get it back to its proper size.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Noted with thanks 🙂
