Unfold problem for a surface like a sliced bowl
emirudlari
emirudlari
Hello, I am designing a musical instrument has half bowl-like body. I will make it by bending and gluing wood pieces. In order to cut them exactly, I need to unfold each part of the bowl (for example, the blue part in this picture). I made this shape by revolving the line (in Patch), and unfold command doesn't work for this shape (in Sheet Metal). Thickness will be about 2 mm. I attached the file, Thank you, Best
Emir
chrisplyler
Fusion 360's Sheet Metal tools do not handle compound curves.
TheCADWhisperer
Port the Fusion stl to Autodesk MeshMixer (free)
or
sign up for Autodesk Inventor Beta http://beta.autodesk.com
lichtzeichenanlage
Or you want to use this service:
[video]
emirudlari
thank you TheCADWhisperer, Meshmixer solved my problem. Best,
Emir
