Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Unexpected result changing a parameter
luca.dalmo
luca.dalmo
Good evening to the community,
I'm very new to Fusion 360 and coming from SketchUp used years ago. I have a question to a problem I cannot come up with.
I design a drawer made of the front, sides and back. Each part is a component. Then I ground the front and I join the other three pieces to each other. Everything is locked to each other.
I go back in the history and edit the first sketch, the one of the front. I increase the height of the component to see the parametric function in action.
I expect all the other pieces to follow by but the result is quite confusing...can anyone help me?
Thank you, Luca
g-andresen
Without insight into your design, advice is unfortunately not possible.
Please share the design.
File > export save as f3d on local device > attach to next post.
günther
luca.dalmo
Hello Gunther,
Thanks for the reply. Here's attached the file.
When I edit the Front Panel sketch and I set the height at 6 in instead of 5, I have a funny result as all the other joint pieces move from the original position.
Regards, Luca
davebYYPCU
Blue sketch lines should keep you awake.
Two sides are defined, two in error are not.
There are no User Parameters in this version.
luca.dalmo
Thank you, I will look into that, first experiences that teach a lot!
g-andresen
I have completed the dimensioning for the sibling parts and corrected/extended the parameter list.
Nevertheless I would only create one part at a time and then copy and assign it.
Here´s a screencast (quick & dirty)
and a file to follow the timeline and parameters
günther
luca.dalmo
Thank you for the explanation and support!
I'm digging more into users parameters now and I'm slowly getting familiar to it. So I understand this is the best approach to the use of the software.
Luca
