Today’s error
Today’s error
Message 1 of 10
Today’s error
What does this error mean?
Replies (9)
Message 2 of 10
daniel_lyall
That is an addon error it has some code that needs to be fixed in it, the text on arc addon get hold of the guy that did it and ask him to fix it if it is better than what fusions version does if not just remove it.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=4400374975546739480&appLang=en&os=Win64
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 10
Fusion is really loosing my interest I can’t pay for this program it’s too buggy I mean here’s today’s new errors - do we even know why?
I’ve attached more error images preventing the program from opening again this morning. Why is this happening ?
When can we just use the program I’m paying monthly to produce some money to eat?
Message 4 of 10
5 years running and I’ve never had this screen open for me yet I don’t even recognize this program what is this ?
why does this program keep flipping from expired to trial to 6 days left warnings and all kinda of buggy clitchiy errors which slow down productivity and kills compleatly a persons workflow.
what is this screen? I have 22 orders to finish in my store and shop I mean I'm on the forum again trying to diagnose software what is going on ?
Message 5 of 10
daniel_lyall
Do a reinstall of fusion something had gone bad.
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 10
g-andresen
maybe some problems were fixed in the  last update
günther
Message 7 of 10
chrisplyler
That error means you don't know how to rotate an image.
Message 8 of 10
TheCADWhisperer
Are you on a Mac or on Windows?
If Windows then Shift Win S (or Windows Snipping Tool).
Message 9 of 10
I have the installed the program and everything is working except this posting error today in a two work offset post - this is interesting...
both setups are side by side on the machine so this second cut of the replete path for work offset g55 shouldn’t be cutting below the first on the left but it’s pictured lower on the screen in the first image and in the second image I’ve changed the machine screen view to show the tool paths from a frontal vantage position and wallaaa fusion code error - the second tool path is turned into a ramp -
I don’t know why ? There both flat 2d tool paths
Message 10 of 10
daniel_lyall
Are you sure the offsets are fine in mach3? sometimes an offset can get stuck.
You will need to post this model.
And use the snipping tool or use print screen and past it into paint then save it, if on mac use the screenshot tool.
Daniel Lyall
The Big Boss
Mach3 User
