Under-cut
Under-cut
dr_thirsty
Under-cut
dr_thirsty
Is there an easy way to make produce an under-cut, on an edge of a cylindrical part? With options?
TrippyLighting
Are you having problems with modeling it, or is ths releated to the CAM workspace ?
What options are you looking for ?
HughesTooling
There are no options in the lathe ops to do that, you will have to model the part with the undercut. Just draw a profile like this then revolve.
Mark
Mark Hughes
Owner, Hughes Tooling
dr_thirsty
Thanks for getting back to me. In the past with other CAD and CAM packages, there has been an option to create standard forms. Like under-cuts etc, using a norm (DIN or ISO). Its a fairly standard thing, when you need to create a machining drawing, that needs further processing, such as grinding afterwards. Modeling is no problem, but is extra time.
dr_thirsty
I know how to do it manually, but an edge preparation function for many standard forms would be a nice feature.
I will suggest it as a possible future upgrade.
