Unable to update newest version
camstuff
camstuff
Update keeps failing. This is day 2 now. I have restarted and moved to different internet connections but no luck.
Any help or ideas?
Thank you
RajkumarIlanchelian
Thank you for posting the logs. Will quickly take a look and see what is going on.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
Once again, thank you for your patience. WE took a look at your logs and know what is going on but the solution at this time for you is to uninstall Fusion 360 and re-install it to be on the latest version of Fusion. I understand this is not the desired solution but with you logs and finding we hope that we can fix the actual root problem.
Please let this thread know if you have any difficulties after you re-install the app.
Autodesk Fusion
Join Fusion Insider
