Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Unable to update drawings.
polyend_mech
polyend_mech
When I open the drawing, I have an info that it refers to a version with more changes, but I am unable to update the drawing to the latest one.
I know that once you introduce a milestone, drawings update to them, but there is nowere to create a new milestone in the model, as I have no popups during the save.
LukasZygmunt
Autodesk Support
Autodesk Support
Hi @polyend_mech,
Could you please provide a bit more detail?
What type of design is this, assembly or hybrid?
Are you using configurations? If possible, could you share the design?
When you open the drawing, right‑click on the view and select Open—which design opens?
Also, do you see any information in the 3D model indicating that the referenced design is not the latest version?
Lukasz
Lukasz Zygmunt
Senior Software QA Engineer
pkomatlapalli
Hello @polyend_mech
I wanted to check in and see if you saw LukasZygmunt follow up questions and requests or if you still needed assistance. If you found a solution to your question already, please share the details so that other community users can benefit from the information.
Pavan Kumar | Community Manager
stiller.design
I have a similar issue. I save a drawing then it tells me it requires an update. so I update, then I save it and it wants me to update again.....
polyend_mech
I am sorry, I must've missed the answer.
The problem solved itself, somehow. At one point the drawing just showed update icon and updated itself to a latest version.
I was trying to recreate the situation, but was unable to do so.
Maybe it was a process of switichng to this new coop mode, can't really tell.
Marcin
polyend_mech
As mentioned before, problem solved itself.
By a process of constatnts saving, updating and swearing I was able to update the drawig. Not sure what was the cause, didn't have the problem again.
As soon, as I come across the same issue again, I will provide the data you asek for.
Marcin
