Unable to switch from mm to in after upgrade
My software updated yesterday, and since then I am only able to draw in mm.
I've gone under Preference > Annotation Units> in, and each time I start a new drawing, it's still mm, am I looking in the wrong place?
I've restarted the software several time and still using "mm".
It was working fine in prior to the upgrade.
Thnx
HughesTooling
I think this might be the setting you need.
Mark
Mark Hughes
Owner, Hughes Tooling
baribak
To change the default units value for designs go into User Menu > Preferences > Default Units > Design.
You will see a dropdown where you can specify which unit you wish to use.
Kevin Baribault
Fusion 360 Quality Assurance
Yep, looking in the wrong place.
Thanks so much for your help!
Im having the same problem, but with the units in "Manufacturing." I have gone to the same settings as listed and changed the settings, then shut down and restarted. Still no luck.
Minutes after I wrote this I figured it out. I had to change it in the top left part of the grid also.
