Unable to set up fusion 360. portable tryout.
Lee14141
Lee14141
On my school we are trying to make a portable version of autodesk fusion 360, so that we can run fusion on each and every computer, of of a usb-stick. It works, until you try to login. After you press the button login, it gives this error: unable to set up fusion 360 for your autodesk account. I'll put in my log file, any help is apreciated!
Lee14141
I've found another log file that might be of help!
Beyondforce
Hi @Lee14141,
Why can't you install it locally?
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Lee14141
Hi BeyondForce,
If we try to install localy our server gets problems with the different virtual disks and machines, so that is could be installed, but not used from every account and device.
Beyondforce
Okay, I'm guessing you are login into a virtual machine and you don't have admin right to install Fusion locally. Is that correct?
Ben Korez
| YouTube
Lee14141
We've solved the error by searching some more. We stumbled upon tis page: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Net... which say this:
Verify settings:
  • The computer's Time and Date settings are set correctly.
  • The user name does not use Special Characters that are not supported.
  • Ports 80 and 443 are open.
  • The following domains have anonymous access through the proxy server for installation.
*.autodesk.com
*.autodesk360.com
*.google-analytics.com
*.akamaiedge.net
The part colored red was the problem, but google analytics is not needed to solve this error, which migth be good to know for people who don't want data mining to happen on their system.
Greets, Leon
huba.czine
Hi Leon,
Would it be possible for you to share a portable version of fusion360.
Many thanks
Huba
