Unable to Select Midpoint in 3D model
gyuneshmehmed
gyuneshmehmed
Hello my colleagues,
I learning from the tutorials and in the tutorial in the link https://f360ap.autodesk.com/courses/mechanical-assemblies-fundamentals/lessons/lesson-3-construction...
, i dont find the mid point after offset plane and Sketch.
I attached 2 pictures, in the first is my drawing and second is the from tutorial.
Thanks.
jeff_strater
it looks as if you may have skipped a step in the tutorial.  The tutorial image shows a line in the sketch.  Yours seems to be missing that line.  You need the line in order to snap to the midpoint:
Jeff Strater
Engineering Director
gyuneshmehmed
I have the same problem in the other tutorials. Maybe this is very simple problem, but i dont know how i select the cirlce because, the circle lines is not showing.
Thanks.
g-andresen
Is it possible that the docking element is in a non-active sketch? Then you have to make contact to this sketch by projecting (p). Or you activate the option autoproject to sketch in the preferences, then it happens automatically.
günther
gyuneshmehmed
Thanks, I activate the option autoproject from preferences and everything is Ok.
