Unable to run Simulation due to Material Issues
Hi
I'm facing material issues trying to simulate a base which I have reconstructed as part of an overall design. However, the solver is unable to solve as it keeps showing that some components are using a material with invalid properties. It is odd as another user is able to simulate it with the same materials as mine. Any ideas?
TheCADWhisperer
Can you show image of your materials Properties?
Is this a linear elastic static analysis?
Are your material Properties isotropic?
Can you File>Export and then Attach your *.f3d file here?
melvinbrian3d
@Anonymousas @TheCADWhisperer said.. .can you share your file or at least a full screen picture of the model.
MelvinBrian3D
shigeaki.k
Hello @Anonymous,
do you have any material property values that are set to "0"? For example, I was able to obtain the same message when I set the Young's modulus to "0".
Shigeaki K.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
