Unable to project construction lines
Brady_Fulton
Message 1 of 41
Brady_Fulton
When I toggle on the construction line setting in the sketch palette and then project onto a sketch the projected lines are not construction lines unless I change them after the project action. Is this the way it is or is it supposed to be projecting lines as construction lines?
Replies (40)
Message 21 of 41
laughingcreek
@stevePPAJF - I'm getting a similar result on a windows machine.  I also think this is a newish bug, as I don't recall seeing this before.
seems to work if I select construction first, but If I select sketch objects first, then the construction toggle is greyed out like in your pic.
Hopefully Jeff will be along to log a bug.
Message 22 of 41
davebYYPCU
Correct, while the Project Tool is active, the sketch pallette is idle.
Message 23 of 41
laughingcreek
for anyone interested-
Message 24 of 41
wersy
Now it is clear to me what was meant.
Yes, you can get a projected construction line as construction line.
Thank you, I didn't notice it. This can really be helpfull.
Message 25 of 41
jeff_strater
sorry, just catching up from vacation.  Yes, this is the behavior that exists today, and has existed this way for a long time.  You have to declare the type you want before you start the Project command.  @davebYYPCU has it right.  While Project is active, the sketch panel cannot start a new command.  The same is true for the Line command.  You have to set Construction before starting the Line command, if you want to draw construction lines.  This is why I mostly don't do that.  I draw everything as "normal", and change to construction afterwards
Jeff Strater
Engineering Director
Message 26 of 41
jhackney1972
I agree with the first part of your statement but for the above statement, I may be misunderstanding your statement but I have no issue changing line types during most any sketching entity command such as line, circle, rectangle, arc, etc.
(view in My Videos)
John Hackney, Retired
Message 27 of 41
laughingcreek
... You have to set Construction before starting the Line command, if you want to draw construction lines.  ...
odd that you have to set construction line first, but you can select center line after.
Message 28 of 41
jeff_strater
You are right, @jhackney1972 - That must have gotten fixed since the last time I tried it.  So, if it is possible for the Line command, it ought to be possible for Project as well.  I'll look into that.
[edit] I created FUS-113478 for this issue.  I don't expect it to get implemented any time soon, TBH, but it is in there...
Jeff Strater
Message 29 of 41
terry_fusion
This is still a thing, it doesn't matter if I select construction before or after I select project it still projects as regular geometry?
Only after I've projected the lines can they be changed to construction, am I missing something?
(view in My Videos)
Message 30 of 41
jhackney1972
I do not see any issue with this process.  You might want to try turning off Projection Link, in the Project Dialog box just to verify it is a construction line.  Notice I put the sketch on a different plane to make sure I could see the type of line.
(view in My Videos)
Message 31 of 41
terry_fusion
Sorry, I must be confused.
How is that helpful?
Turn off projection link and lose the very reason I'm projecting the geometry?
And to have to create a  plane to project to for it to work?
It worked as expected when I created the additional plane to project to but not on the face of body?
I must be missing something?
When I project geometry I want it linked to the face/feature I've projected it from. I should be able to project onto the surface I need and not have to create addition planes to do it.
Message 32 of 41
jhackney1972
No, you do not have to do any of that, I just created a plane and turned off the projection link to make sure you could see the Project created a construction line type.  I just did all of that to make sure you see that it works.
Message 33 of 41
terry_fusion
(view in My Videos)
But apparently I do need to do all of the extra if I want it to project properly.
If I project onto a plane I can project as linked or non-linked and construction or regular but not on the surface of the body?
For me that's where the rub is.
I appreciate you taking the time to help, and again maybe I'm missing something basic?
Message 34 of 41
jhackney1972
Here is a video showing the creation of a Projected Construction Line, with Linked Projection on a body surface.
(view in My Videos)
Message 35 of 41
terry_fusion
Whats going on then?
I've repeated the exact same thing several times and still receive the same as every other time but different results as you.
It doesn't appear that I'm doing anything exotic or different?
Why the discrepancy?
Right now for me this is still unresolved.
Thanks again for trying with me, honestly I'm not trying to be difficult.
Message 36 of 41
jhackney1972
The only thing I can suggest is to use the Fusion 360 Service Utility and the Repair Option to try and fix your installation.
Message 37 of 41
terry_fusion
Tried both the reset first and repair second, neither made a difference in the outcome.
The only difference may be the OS?
Windows 11 Pro here
Which is kind of weird because looking at the about in the help menu it returns Windows 10 Pro
Message 38 of 41
jhackney1972
I am using Windows 11 operating system and it functions normally.  My About says Windows 10 Pro also.  I am at a lost what you can try next.
Message 39 of 41
terry_fusion
Thanks for sticking with me through this and keeping your patience. 👍
I'm also at a loss, but its a small thing I'm sure I'll manage to survive  😉
Message 40 of 41
mathieugariepy.00
Getting the same error now on the newest version (2602.1.25 x86_64).
Start sketch, press P for project, select typeline as construction, select face needed, lines appear...
I work everyday with Inventor it does not do this but at home with Fusion is getting pretty annoying, I reference tons of features constantly in my designs.
