@chrisplyler Good question. In all actuality, it isn't a "problem" per se, as you point out you can "get around" this feature request by a variety of methods (one of which is just "pretend the workspace is a different size in your head"). However, one might then use that same logic to argue "why have options for mm and inches? Just convert everything to inches before you start drafting, no need for a feature request...".
The main reason for the request is the same reason for any feature request: improve the user experience. Although one user might not see the value in something, a ton of other users might love it (and might have already been asking for it for several years now, as made evident by this unresolved thread...).
To perhaps more directly answer your question with some examples:
- A user may want to scale one or several models in the same workspace to maximize their size to fit the print volume, requiring adjustment of position on the workspace not only within the bounds but in relation to one another:
- A user may want maximize the print by placing as many models in the print area (again, considering placement, rotation, etc. with respect to each other).
- A user may want to consider printing a model in parts (rather than a whole) after seeing how it fit within the print bounds.
Basically, the idea hinges around users for 3D printers not always designing models to exact specifications. At times they need to visually see how they can play around with the print area to maximize their designs when printing multiple jobs at once.
Overall, I agree that this is a minor request (but at the same time usually means "low hanging fruit" to please the user demand). The main thing I would like to see is Autodesk reply to these threads with either "will not implement" or "will implement soon", rather than misinterpret the question, link to an answer for a question that wasn't asked, and not follow-up on the thread when another user correctly points this out (@Anonymous) . Otherwise, users will keep searching around, keep asking if this exists and keep asking for this feature request.
