unable to press pull sketch
s.kishore1998
s.kishore1998
I am trying to follow product documentation given in http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-E24C20F4-E5E0-4585-A1DF-0BE8CDDC787D . In step 5b when I try to select the 6 points it selects the face and  I can't select the sketch.Screenshot (28).png
i don't know what's wrong with the design?
laughingcreek
When you did the sketch pattern, you only patterned the center point of the circle, not the circle itself.  go back to the sketch and edit the pattern (double click the circular pattern icon) and add the actual circle to the pattern
sanket223.patil
Hello @s.kishore1998
I checked your design, In the sketch, you have circular patterned only the centre point of the circle, not the circle. I will encourage you to edit the sketch and double click on the circular pattern symbol and redo the selection so you could get 6 circles. After the sketch, select all circle profiles and use press pull to extrude it. During the selection of circle profile, I will recommend you to zoom closer and then select the profile. I have attached the design file
Sanket Patil
Mechanical Engineering
Expert Elite
