Unable to open fusion 360
nikhilr117
Observer Observer
nikhilr117
Observer
Observer
I am unable to open fusion 360. There are two errors popping up.
the first one says u have not gone online since two weeks so sign in to continue
the second "unable to connect to the internet. please sign in your autodesk account to continue".( Even though my system is connected to net.
I have tried some solutions posted in this website but they didnt work.
please help me out with this.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @nikhilr117,
Welcome to the Fusion 360 Community!
I am sorry to hear this is happening to you! Just to check - have you had Fusion 360 working correctly in the past and it just stopped working, or has it never worked before? To troubleshoot this further I will need your installation log files as well as your application log files. For the application log files, try to sort them by date and grab the most latest one. Can you please post both of those here or email them to me at james.youmatz@autodesk.com. You can find those files by following the steps in this guide here
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
baribak
Can you try deleting the Web Services folder then launch Fusion? This should take you to the login screen.
You can use Explorer/Finder to navigate to the Autodesk folder on your system. Then Web Services folder can be found here:
   Windows - c:\users\<username>\appdata\local\autodesk
   OSX - /users/<username>/library/application support/autodesk
If it has been a while since you last logged in you may also see an update being downloaded.
Hope this helps.
Kevin Baribault
Fusion 360 Quality Assurance
nikhilr117
Observer
Observer
I tried deleting the folder but it didnt work.
Is there a problem if i uninstall and reinstall again?? will i lose my
data(projects)??
baribak
>> Is there a problem if i uninstall and reinstall again?? will i lose my data(projects)??
No you will not. The projects/folders/files are stored in the cloud.
You can access them not only in Fusion but also via a web browser (e.g. Chrome) by signing into myhub.autodesk360.com.
To uninstall follow these instructions:
1. Go to the Start Menu > Control Panel > Uninstall Programs.
2. Select the existing Autodesk Fusion 360  entry from the list and click Uninstall.
3. Upon completion of the uninstall program exit Control Panel.
     Clearing remaining program files:
1. Launch Windows Explorer.
2. Navigate to: C:\Users\<username>\AppData\Local\Autodesk
3. Delete the following folders (if present):
              - Autodesk Fusion 360
              - Web Services
              - Webdeploy
              - production
              - Neutron Platform
              - Neutron
4. Next, navigate to: C:\Users\<username>\AppData\Local\Autodesk\Common
5. Delete the following folders:
              - Material Library
              - DB Manager
              - Exchange Archives
6. Next, navigate to: C:\Users\<username>\AppData\Local\Temp
7. Delete the following folders:
              - 7Z*.*
              - Autodesk
              - ProtoLabs
              - Neutron
8. Now navigate to C:\Users\<username>\AppData\Roaming\Autodesk
9. Ensure the following folders have been deleted. If they haven’t, manually delete them.
              - MC3
              - Neutron Platform
              - NINVFUS
              - Synergy
10. Next navigate to C:\Program Data\Autodesk
11. Ensure the following folders have been deleted. If they haven’t, manually delete them.
             - MC3
             - Neutron
             - NINVFUS
Kevin Baribault
nikhilr117
Observer
Observer
Please kindly suggest an another alternative for the bug(Unable to connect
to the internet) as unistalling it is a big process.
baribak
To quickly perform the uninstall use Control Panel. Once that process completes restart the system and you should be able to reinstall.
Kevin Baribault
