Unable to merge face or select faces to stitch
Hi all,
I have an imported stl file that I converted to BRep.  I wish to merge the faces so a can perform an extrude function.  When I select 2 adjacent faces to merge i get a "Failed to merge or stitch" error.  When I try to stitch two faces I can't even select anything.  I'm relatively new so probably doing something stupid. Have tried turning time line and and off but no luck.
SaeedHamza
The merge command should do it with the chain selection on
If it's not working please hare the .f3d file to your next post
Regards
Saeed Hamza
Hi Saeed,
Chain command selected all the faces but still failed to merge.  Have attached f3d file.
David
SaeedHamza
There is something so missed up in your model that makes Fusion crash every time I try to merge faces ... and I just don't get what it is to be honest
But still, this model can sooo easily be done in Fusion's Model Workspace, so why import it as a mesh?!
Saeed Hamza
Simply because the dimensions for the drone motors etc were already done.  Did not realise there would be issues converting to f3d to do some modifications.  Seems like the file has become corrupted somehow during conversion so will have to create from scratch.  Thanks for helping out.
SaeedHamza
It won't be hard to start it over again in Fusion, not to mention that you'll have sketches and parameters to modify as you like
Saeed Hamza
True.  Will do so and the extra experience is always useful.  Cheers
