Unable to make a fillet by selecting the junction
I am just following this,
https://www.youtube.com/watch?v=2Hd348CNQ1Q
and at 3:34 I should be able to select a line and make a fillet, I have done so before before the fusion 360 upgrade but now I seem unable to.  Am I in some sort of wrong mode? or bug?  or?
I select fillet but a sketch palett menu appears and not a fillet menu?  Am i in a wrong mode or something?
Just made a second model, seems I have the same in-ability to make a fillet as I cannot select the line between the two sides.  As far as I can tell I am following the tutorial exactly....and Ive done this tutorial a few time sperviously but now I cannot......confused....
michallach81
First, you need to be in MODEL environment, second check SELECT tab, you need to have checked Body Edges option.
Michał
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
jeff_strater
it sounds like you are using the Sketch Fillet command, not the Model Fillet command.  You wan this command:
Not this one:
Jeff Strater
Engineering Director
You are correct.....doh.
Thanks, great application and the change since Autocad14 / LT97 (last time I used a CAD program) is immense but so many options means its so easy to get lost in even simple things.  😞
My son is also doing the tutorials and had the same issue, maybe the interface needs tweaking to reduce confusion.
