Unable to load or edit uploaded f3d file
m.a.peletier
m.a.peletier
I got an error "Unable to create A360 item for this file, please try again later"; to save my unsaved work, I exported the work as a f3d file. Now I'm trying to re-import the work again.
However, upon uploading the f3d file, the Dashboard shows the file but with a f3d logo instead of the usual cube logo, and the data panel in Fustion360 itself the same. If I click on the file in the data panel, the software opens autodesk360 on the file.
How do I get Fusion to recognize this file, or this work, as native, and let me continue on it?
Yours,
Mark
m.a.peletier
I solved my own problem: by right-clicking on the file in the data panel, one can choose Create Fusion Design, and that created a second file which Fusion can read. The timeline was also preserved.
HughesTooling
You can also use New Design From File to import f3d file without uploading them to Dashboard.
Mark
Mark Hughes
Owner, Hughes Tooling
m.a.peletier
I hadn't seen that one. Great, thanks!
