Message 1 of 9
Unable To Join Solid Bodies
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been trying to create a single solid body, of a complex curved fairing, as follows
- Lofted sections of sketch = Surface Bodies
Nb: The entire sketches for the fairing could not be lofted together as "The loft would intersect itself", however individual sections were lofted OK. - The Surface Bodies were stitched together = single Stitched Surface Body
- Thickened each part of stitched Body as F360 could not do all together = individual Solid Bodies
(Body57 to Body67) - Join Bodies - two Bodies won't Join others - Body59 and Body60
- As per Forum-Unable To Combine ,
a. turned off Design History, for direct modelling mode
b. used Inspect -> Validate to check, reports AOK
c. Re-enabled Design History - and found it was all GONE - and Sketches could not be edited!!!
I've spent many hours researching and trying to find a way to create a 3mm thick fairing from the sketches, and thought I'd gotten there until this last issue. I have attached the previous version - before I went to Direct Modelling and wiped out the History - in the hope that someone might see what I'm doing wrong.
