Unable to import multiple stl file properly
Previously before the update, I can import multiple STL file into the design and all of them automatically positioned to their original position. Now after the update, I imports same STL files in and they positioned away from each other. How can I reposition them to the original position?
Mike.Grau
Hi @Anonymous
Thank your for pointing to that.
Unfortunately, we noticed this as well and you probably see your issue in this post here.
http://forums.autodesk.com/t5/design-validate-document/move-command-in-mesh-module-losses-the-pivot-3d-widget/m-p/6467700#M66155
I got already in touch with the Fusion 360 development team and we do work on that.
I´ll keep you updated on that.
