I am a very beginner to Fusion 360, so sorry if this is a very dumb question. I am attempting to make a tab for a lid, two of which I have done on the sides, and two more which I would like to create on the top and bottom. For this, I offset a plane to the desired length, then created a sketch on the plane. However, when I go to create a line on the plane, it makes these purple lines. If I am on more than one of the lines, the sketch does not close or is not recognized as a plane. But, if the sketch starts and ends on the same line, then Fusion recognizes the face. I have attached a photo below which shows the offset plane, as well as examples of what does and does not work. When I am creating the sketch, I do use side view, by the way. Is there any way to fix this? I wasn't facing the problem on the sides, although the sides are a lot straighter.
