- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I ran into an issue where I was unable to export custom ranges of sheets on a large drawing set. I could export the whole drawing set and some smaller subsets of sheets, but once the custom range got over ~15 sheets, nothing would happen when I tried to export. No error, no crash, but no PDF either. I finally figured out the issue seems to be long sheet names as a result of copying sheets over and over. I ended up with sheet names like "Sheet1-Copy-Copy-Copy...". Renaming all the sheets to something more reasonable solved the issue. Wanted to make a post in case someone else runs into the same issue.
I've notified Autodesk, so they know about the issue. Hopefully they can either fix the underlying issue or change the default naming convention when copying sheets to avoid the super long sheet names.
