Unable to edit joint.
Marcin_Bortkiewicz
Marcin_Bortkiewicz
Hi there.
Having a small issue with editing/ reconnectimg the joint.
I am unable to pick the joint origin, or the component at all when trying to fix a proken joint.
I would like to keep mentioned component, as there is a sketch based on it, in a different assembly.
Any ideas how to fix it?
davebYYPCU
To edit the Joint or Joint Origin location, in a Linked Component or Assembly you will need to Edit in Place or
fix it in the original file.
Might help...
Joint origin is ok. I can't reconnect to it.
...  I can't reconnect to it. Correct,
you can't edit anything in a Linked Component (that's why it's opaque,) without Edit in Place, or going to the original file.
The bad Joint is in the Linked Assembly
Might help....
