Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Unable to cut body, despite files being validated properly.
2 REPLIES 2
Koyodee
234 Views, 2 Replies
I'm having troubles cutting 0.08mm from one of the faces, to make it flush with my other component. All of the other 18 faces worked just fine, but this one face is giving me an error. I've turned off capture design history and validated all the files, but it said they were all fine. The error I'm getting is shown in the bottom right of my screenshot, but I also attached my fusion file. Any suggestions are greatly appreciated. Thanks
2 REPLIES 2
jeff_strater
in reply to: Koyodee
it looks like Press/Pull or Offset Faces (same command, really) works to remove 0.08 from these faces:
I notice that you are not using parametric design history in this design.  Out of curiosity, was that an intentional choice?  Just interested in why some people choose direct modeling over parametric modeling, not implying any criticism.
Jeff Strater
Engineering Director
Koyodee
in reply to: jeff_strater
I was originally in parametric, but one possible solution I saw was to change to direct and validate the files. I did parametric for the model up to this point though.
