Unable to create a solid from a custom surface
g.abbinkN9ZY3
g.abbinkN9ZY3
I've been working with Fusion for a while but I can't figure out how to create a solid from a custom surface.
I've created a surface based on another object and need it thickened. Tried multiple things but just can't create a solid.
If any information is needed I will try my best to answer them and provide you with more information
Hope this can be solved
wmhazzard
You might have self intersecting surfaces, please attach an f3d file of your model. Also please use the insert photo option instead of attaching them.
g.abbinkN9ZY3
Thanks for the quick reply,
Here's the F3d file as requested
mango.freund
mango.freund
Take a picture of yourself and put it on calvas. then cut out the nasal areas. greetings mango
g.abbinkN9ZY3
Thanks for replying,
I don't really understand why you've send the mask back to me. Also I do not really understand your explanation
