Unable to constrain SVG
parapants
parapants
Hello.
I have an extruded panel with a cut out dog paw. The panel size is changeable with parameters, so I would like the Paw to remain 10 inches up from the bottom, and 8 inches from the right side of the panel. I removed the fix, but can't figure out how to constrain the 5 pieces, or keep them grouped.  Simply adding dimensions separately to each piece of the paw caused the graphic to rotate as the dimensions change.
Any help is appreciated. Thank you
Drewpan
An SVG is a Scaled Vector Graphic - it is NOT a Sketch, nor recognised as a Sketch by Fusion. It can be Sketch-like
and there are things that can be done to it like a sketch but they are not interchangeable.
I would suggest that if you want to constrain and parameterise the svg then you will need to use it as a canvas and
redraw it as a parametric drawing with all of the associated geometry, dimensions and constraints. Then it will scale
by changing parameters, including you positioning parameters that you can fix.
Cheers
Andrew
parapants
Thank you.  I took your advise, and now it is a series of lines instead of an SVG.
But, I'm still stuck.  What I want to do is "group" these 5 entities, and then put a horizontal and vertical dimension to the sides of the panel so they move as the panel is adjusted with parameters.  I can't seem to treat any entity, let alone all five, as an object with constraints or sketch dimensions to place them where I want them.
Any ideas?
laughingcreek
put the sketch in it's own sub component and control the position via a joint.
parapants
Thank you @laughingcreek.  I was able to reproduce what you have done, but then what I thought was easy...wasn't.  The Paw design was to be cut into the panel.  I tried doing it in the Paw Component referencing the Right Riser (the panel), but I'm getting the error "Compute Failed: No target body".  Any help would be appreciated.
g-andresen
might help
günther
parapants
Thank you @g-andresen.  Simple mistakes are the hardest to find.  Odd part was I could see the outline of the paw on both sides of the panel so I thought I was cutting in the right direction.  Just needed to look closer.
