- Mute
- Permalink
- Report
Hello.
I have an extruded panel with a cut out dog paw. The panel size is changeable with parameters, so I would like the Paw to remain 10 inches up from the bottom, and 8 inches from the right side of the panel. I removed the fix, but can't figure out how to constrain the 5 pieces, or keep them grouped. Simply adding dimensions separately to each piece of the paw caused the graphic to rotate as the dimensions change.
Any help is appreciated. Thank you
