Unable to add draft to more than one face
nkloski
nkloski
This should be a simple thing......I have a design where I want to add a draft angle to several faces.   The draft command allows me to add the draft just fine to all faces.  I then go model some more, and find out I forgot one face.
Scrolling back in timeline, I cannot add any face to that command.
I also cannot initiate a new Draft command and draft any more than one face at a time (no multiple selections).
Here is a screencast of a simple cube, showing that I cannot select more than one face...why?
Thanks!
Nick Kloski
nkloski
Ah, and no sooner than running into this multiple times, that I actually learned how to use this more fully.  If you read the on-screen prompt, you have to hold down the Ctrl key, and that allows you to select more faces.
Nick Kloski
