Cannot section body and remove unwanted part
men8ifr
men8ifr
Probably a very simple question.
I have a body I want to section, that appears to work fine and it creates a new body. If I look at the 2 bodies the original now has a hole in it (correct) and the new body appears to be the part I wanted to remove. (correct)
If I delete the part I don't want body9 (right click on the body name on the tree on the left and select delete) then the original body has this part back again.. Fusion 3.JPGFusion1.JPGFusion2.JPG
davebYYPCU
Right click and select Remove, delete is not the correct command to keep the timeline happy.
Might help...
TrippyLighting
Looking at the timeline, your construction workflow is problem very inefficient.
Moving a scaling are not the proper tools to design such an object.
