UI Preview - Create Sketch - Change Parameters
durahl
durahl
Greetings!
I'm currently using F360 with the UI Preview enabled from the Settings Menu and one thing I noticed very quickly is the lack of a Change Parameters button in the new Ribbon Menu when working in the Create Sketch Environment.
I for one use the Change Parameters functionality quite a lot while in the Sketch Environment and not being able to access it from there is kind of an inconvenience as it forces me to exit to another mode, like Solids or Sheet Metal to do so.
While we're at it I was wondering if we could also have the possibility to PIN the Change Parameters Window to remain open even while we're not actively using it? I have a 4 Monitor Setup with 3 next to each other and it would REALLY boost my workflow if I could have the Change Parameters Window remain open on one of them while doing 3D work in another and ( already possible ) have a 2nd instance of F360 open on the 3rd Monitor to copy/paste information from when redoing a Project.
Thanks in Advance 😃
HughesTooling
For now you can add it to the shortcuts dialog, press S then start typing Parameters and add it to the dialog. Other option is add a hotkey, you can select the solids tab while the sketch is active or is that what you mean by exit to another mode.
Mark
Mark Hughes
Owner, Hughes Tooling
Is there any chance to keep the change parameters icon permanently on the toolbar? Parameters will affect the entire design so IMO it would make sense.
jas
Observer
Observer
Yep, I agree. I use parameters a lot (given Fusion 360 is parametric!). There needs to be an option to have this back on the ribbon.
keqingsong
Thanks for calling this out you guys - Change Parameters has been added to the Sketch > Modify panel and will be available in the next update.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
durahl
Click MeClick Me
