Sometimes (typically when opening files and switching applications while doing so) UI elements seem to be disconnected from Fusion and remain on top of all the other windows. Switching applications does nothing to remove this strangeness; clicking on a UI element, however, seems to restore the behavior to normal. Fusion no longer steals focus in the same way that it used to, but this is annoying. I am fairly certain this is unintended behavior.
Solved by paul.clauss. Go to Solution.
Hi @neljoshua
This is certainly unintended behavior - I have seen this consistently on my Mac as well. I have logged a new report for this problem, FUS-30470, with our development team. They will be looking into this issue and I will circle back here to provide an update when I have more information to share.
Thanks!
Hi @neljoshua
Thanks!
Thanks for looking into it.
Any updates on this? It is still not fixed.
Hi @neljoshua
Unfortunately this ticket is still unresolved. The development team is aware of this and will be working on it as soon as possible. We apologize for any inconveniences this has caused - I will keep you updated as I have more information to share.
Hi @neljoshua
2018 is here and I'm still experiencing this bug on a daily basis. It's quite frustrating, especially when exporting an stl to a slicer like Simplify3d. Every single time the browser panel stays above Simplify3d.
Not to be too snarky but it's now.... 2022 and I still have this issue on Windows and Mac. Any updates?
I'm noticing the same thing on my M2 MacBook Air.
I also see this happening all the time on my mac.
