UI bug in joint edit dialogue prevents edits
01:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The joint command has a bug: If you need to edit the joint, a "lost reference" error message embedded in the object select tab is so long, and joint edit dialogue box is so narrow (and we are unable to widen it) that the object deselect control, the little "x", is hidden and inaccessible. So you can't deselect the offending "missing object" and reattach a good one. See the attached image which makes this point clear.
