Twisted patterns along a path
- Mute
- Permalink
- Report
Hello all,
I'm trying to design various miniature roller coaster track sections which will be manufactured and assembled later on.
These consist of two rails and a central spine, with spoke-like shapes connecting them every 50mm or so.
Making straight and arced rails has been relatively straightforward with sweeps for the rails and patterns along a path for the spokes, but I've run into difficulty getting this to work for a twisted section of track, as you see below:
As you can see, the sweep is able to twist through 45 degrees but I don't see any option to twist the spokes along their path so that they align with the rails and spine.
I've heard some rumours that i'll need to get to grips with inventor to be able to do this but I would appreciate it if anyone has a suggestion for a workaround (even if it seems tedious it will probably take me less time than switching over to inventor and getting set up on it)
Thanks very much
Harry
