Turning Timeline into Macro
Is there possibly a way inside Fusion 360 to simply create a Macro (= a silly action repeater in the sense of
say a Photoshop action) from the timeline? The idea is that one "records" a sequence of actions with a
sample surface as input (extrude it's  boundary a couple of times and cap to form a solid) and being able
to repeat the same automated Limbo with other similarly shaped but not identical surfaces.
Is that a concept which already exists somewhere in the program or does one need to resort to scripting?
Thanks for all hints!
I guess the answer is no then? Would seem quite useful to me 🐵
TrippyLighting
No, that functionality does not exist.
However, Fusion 360 has a very extensive API that covers several languages. e.g. Python. If you are familiar with it you can programs such things yourself. But that is definitely more complicated than just a recorded macro.
O.Tan
Nope, doesn't exist and you'll probably have to resort to scripting
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Trippy Lighting and O.Tan,
thank you both! I am pretty convinced that what I have in mind was solvable in that straightforward Photoshop way
(use file history – apply to other input – possible enter Features for tweaking after the fact). We'll look into scripting this then.
